350 SBC starting problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-15-2009, 07:41 AM
sbchevy s10
hi i am new at this but i have a question i have a 1977 350 chevy casting 3970010 and wen i start it and let it run 4 a while an turn it off. then try to start it again it crank really hard like its lout of time
Old 01-15-2009, 07:46 AM
poncho62's Avatar
Wiki Edits: 5
welcome.....I am moving this to Hotrodding basics forum
It sounds to me like you have.....a bad battery, loose connections,or bad starter....or all of the above.
Old 01-15-2009, 08:33 AM
eastboundanddown's Avatar
eastboundanddown
Last journal entry: NO SON, LET'S WALK DOWN THE HILL...
A thought???
Does it have headers, or is the starter getting heated up from exhaust?? If so, some Cool Tape goes a long way---
Old 01-15-2009, 09:14 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
It sounds like starter heat soak.....they have remote solenoid kits for this...check with jeggs or Summit.
Need 350 SBC to 350 Turbo Torque Specs MikeD Transmission - Rearend 2 10-20-2013 09:26 AM
Need Help FAST!!!!!!!!!! millertime85 Engine 14 06-25-2008 07:01 PM
Engine starting problem..350 sbc.. freeman437 Electrical 5 08-14-2005 08:25 AM
350 sbc HP/TQ question stfinney Engine 10 03-04-2003 02:49 PM
question on starting a 350 sbc stfinney Engine 8 02-20-2003 09:24 PM
