350 SBC Timing - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2003, 08:42 AM
Daved's Avatar
New Member
350 SBC Timing
Just a quick question,
I have a Small Block Chevy 350 and would like to know what I should set the idle timing to, it is way off at the moment!
Thanks for you help
Old 06-16-2003, 09:29 AM
Hollywooding's Avatar
Canknuckle Head
Generally timing is an individual thing really. However there are some good guidelines. If it's a stock motor try aiming for 8 - 10 degrees, don't pull the apprentice move and leave the vaccuum advance on, and then just play with it. move in 2 degree increments till you get the most power.
Lot's of mechanics will tell you that you can set it by ear, just listen for the motor to 'ping' and then back it off a degree or 2. Either way has worked for years.
PS if the timing is really, really, really off, maybe your timing chain jumped, or you have a vacuum leak.
Either way now you should know where to start.
Smilin' Mike
Hollywooding :cool:
