Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350 SBC / Vortec Heads: Cam Choice?
Old 12-11-2012, 04:37 PM
Stoppy Stoppy is offline
Vortec Heads
I did the same this past July. With the performance chevy intake make sure you do the cooling update in the first paragraph of the instructions. Then you will need a chip to make it run because it will be too lean. Motorvation is great to work with and they will send you chips till you are happy. Just tell them what you have and what you did and what you want. Very smart on the older fuel injections. Can also be reached through summit. Good luck CYA Joe
