350 sbc won't start! - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2012, 05:36 PM
EazyDuzIt102's Avatar
1965 Impala SS Convertible
Just dropped a 350 into my 65 impala. Everything is connected and good but when I turn the engine over, it won't fire up. The engine ran before it was pulled out of the car. While the engine was out I did put a new timing chain/gears on. Is it possible I didn't install the timing set properly? Or maybe im not getting spark? What test could I do to see if I am getting spark? The carb seems to be getting fuel. Any help is appreciated. Thanks
Old 09-04-2012, 05:52 PM
pull a plug while connected to the wire still and hold it against something like your headers or the block to ground it and have someone crank over the engine and you should see something, the spark should be all blue. BTW you might get a small shock but youll live, use rubber handled pliers or something.
Old 09-04-2012, 05:58 PM
Ok I'll try that
Old 09-05-2012, 07:21 AM
delawarebill's Avatar
no start'n
when u put in the chain/gears.. i'll assume u put them in pointing to ea other.. top at 6 and bottom a 12... then u need to put the dizzy in pointing at #6 cyl.. if u put it in a #1 ur 180 out.. not a biggie.. been there done that...
Old 09-05-2012, 11:50 AM
Ive never heard of facing the dist to the #6? When i re installed the distributor I dropped it in facing the #1 and had the balancer mark on 0. Was that incorrect?
Old 09-05-2012, 11:52 AM
And yes, I installed the gears and chain exactly how you said.
Old 09-05-2012, 01:43 PM
When installing the timing gears you install them-timing chain gear at 6:00 and crank gear at 12:00. Actually this is the exhaust stroke, turn the crank one revolution, the crank gear will be at 12:00, the timing chain gear will be at 12:00. You can then drop the distributor in pointing at #1 this is the compression stroke. You could have stop on 6:00 & 12:00 and dropped the distributor in on #6 like delawarebill said.
Old 09-05-2012, 01:45 PM
Did you check if you have fire to the plugs?
350, chevy
350 Chevy won't start Stretch3663 Engine 12 09-15-2013 10:00 PM
Sbc won't start, I'm guessing?? HELP kingofny1997 Hotrodding Basics 6 08-25-2012 09:25 PM
Rebuilt 350 won't start pukas84 Engine 35 12-19-2011 09:28 PM
350 Won't Start.... STATUTORY GRAPE Engine 5 05-29-2009 07:13 AM
72 350 w/ HEI won't start roadbase Engine 3 07-14-2005 01:33 AM
