350 Shifting to soon? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2010, 09:18 AM
Mertz's Avatar
72 Chevy 3/4 ton pickup. I installed a quadrajet and it is working great. I adjusted the transmission cable with the throttle wide open and then connected the cable. I pulled a trailer for the first time today and going up a steep grade at 55 is down shifted up shifted and down shifted several times very quickly. When I got down to 50 it down shifted and stayed there until I got to the top of the hill. It seems to be shifting early without the trailer as well. I have a stock converter and rebuilt trans with a shift kit. Is the cable to tight?
Old 07-02-2010, 03:11 PM
I'm going to stick my face into the obvious first
Is the kickdown the only thing you adjusted right before prob, or did you install tranny+adjust cable before prob? In other words,did it ever act right? If yes to that then its your kickdown adjustment. If no to that it could be(oh geez wer do I start the list) kickdown,modulator,vac leak,governor,etc etc etc
Old 07-02-2010, 09:25 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Sounds like it's too long if anything (early upshift).With the throttle blades closed, engine off, look at the cable. You will see a "lock" of sorts that when lifted up, will allow the cable to retract very short. This lock can be hard to lift by hand, you might want to use a screwdriver to lever it up.
Then get into the car and floor the accelerator pedal. That will set the cable. If need be, you can fine tune it a bit tighter or looser than this setting.
Old 07-06-2010, 11:31 AM
Mertz's Avatar
The cable was set too short. I undid the clip and opened the throttle by hand and it moved quite a bit. I locked it down and now it seems to be shifting correctly. I haven't tried with the trailer yet but I will on Thursay when I leave for 2 weeks of fly fishing on the St Joe River in Idaho.
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
new block mikey1476 Engine 8 04-12-2009 09:34 PM
th 350 shifting issues frankenstang57 Transmission - Rearend 2 04-20-2005 03:56 PM
camaro transmission still not shifting chevcamz28newbie Transmission - Rearend 2 07-20-2003 07:33 AM
