350 small block - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-26-2012, 06:26 AM
350 small block
i recently rebuilt my sbc 350 and put a .485 lift camm ,springs... my question is, can i still use my stock converter with this set up?
Old 03-26-2012, 07:10 AM
delawarebill's Avatar
converter ??
sure.... if it worked fine before, a little bit more lift on a cam is not a biggie.. if u r using a super loopie cam u may need to move up on the rpm of converter... what veh ????
Old 03-26-2012, 12:37 PM
its in a 87 monte carlo, but the motor came out of a 78 camero
Old 03-26-2012, 12:46 PM
327NUT's Avatar
Lift is really not that important, what the duration and intake centerline numbers?
Old 03-26-2012, 01:09 PM
not sure what the duration is....
Old 03-26-2012, 01:16 PM
327NUT's Avatar
You didn't throw away the cam spec sheet or did you install the cam? These specs are important when choosing other parts to go with your engine/trans combo.
Old 03-26-2012, 03:00 PM
yes i didnt see a spec sheet and yes i installed the cam and valve springs,,
Old 03-27-2012, 05:56 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The duration/overlap/intake valve closing point/LSA has to do w/what stall speed may be needed, not the lift per se. If you have a cam card for this cam, the specs are there.
You'll know soon enough if the cam was put into the engine w/the engine in the car- when you drop it into gear the first time if it pulls through the brakes, you will need more stall speed. If the engine is out of the vehicle, now is the time to decide on the TC, and we'll need the specs as well as a run down on the vehicle to make a recommendation.
There are some crutches that may help a too-tight TC, but in the end, the TC has to match the cam for best results.
Big block pil pump on small block Chevy dallam11 Engine 22 03-24-2012 07:36 PM
Can You I D a Block & Heads Small Block Chevy please? Rob Keller Engine 19 01-30-2011 08:39 AM
Big block water pump on small block! TVR383 Engine 14 04-15-2008 07:43 AM
are 1 5/8 long tubes too small for a 414 ci small block? tony350ss Engine 8 03-17-2003 11:45 AM
Small Block 400ci...or...Big Block 396ci???? chevyelc81 Engine 17 10-05-2002 07:06 AM
