Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350 small block vortec problems, stalls out
  #22 (permalink)
Old 01-13-2013, 09:55 PM
Camaro_Nut2001's Avatar
Camaro_Nut2001 Camaro_Nut2001 is offline
Drag Racing Lover
Last journal entry: '68 Impala Project
Originally Posted by Ltsulli1 View Post
There are no vacuum lines to the trans nor cables atached to the motor/carb from the 350 turbo trans. Thanks for any input!
If this is the case you must not have a turbo. I have saw alot of rubber vacuum lines at the modulator dry rot and cause a bad leak. I would check the tee or port coming out of the intake behind the carb. Should be a rubber line running from it to a small diameter metal line that runs right down between the firewall and right side head, probably close to your trans dip stick tube, and runs to your modulator valve. Also, you should have your passing gear cable coming up on the left side running to your carb. Now some people that are in a hurry dont even bother with the passing gear cable so it may be tied up out of the way. I assume you are not running a reverse valve body so the cable should be hooked up.
