Thank you for that info
Vortec heads only need 32 degrees total timing, not counting vacuum advance. More on setting up the timing correctly is linked to below. Until you get the timing sorted out, you're going to have a hard time w/idle quality, nozzle drip, off idle response, etc. Use a vacuum advance limited to 10 degrees, use ported vacuum for it. If you find you're still having a problem getting a balance between idle quality and initial advance (advance isn't helping enough), you may need to add idle bypass air. Not all Q-jets have a threaded rear port for a power brake booster. Use a manifold port if yours doesn't. The front large vacuum port is for the PCV valve. Carb vacuum port ID Advance curve You most likely do need more stall, but sort the timing out first, then see what you need if anything. Last edited by cobalt327; 01-12-2013 at 06:33 PM. |
| The Following User Says Thank You to cobalt327 For This Useful Post: | ||
Ltsulli1 (01-13-2013) | ||
If you are using a vacuum advance connected to manifold (full time) vacuum, this can cause the engine to stall if you don't have enough initial timing. When it goes into gear, the vacuum drops off. This can cause the vacuum advance to drop off as well, and you lose the timing it was supplying. That's why I said to add initial timing- as much as the engine needs- then to use ported vacuum for the vacuum advance. |
If this is the case you must not have a turbo. I have saw alot of rubber vacuum lines at the modulator dry rot and cause a bad leak. I would check the tee or port coming out of the intake behind the carb. Should be a rubber line running from it to a small diameter metal line that runs right down between the firewall and right side head, probably close to your trans dip stick tube, and runs to your modulator valve. Also, you should have your passing gear cable coming up on the left side running to your carb. Now some people that are in a hurry dont even bother with the passing gear cable so it may be tied up out of the way. I assume you are not running a reverse valve body so the cable should be hooked up.
350 small block vortec problems, stalls out
Look at the transmission pan on your car. A 350 turbo has a square pan with the right rear corner cut off. The turbo 400 has a odd looking oil pan with two or three dimples on the bottom of the pan. check yours to see which one it matches. Do you have the part# for your camshaft?
It's very possible the modulator just isn't hooked up. There's not many GM automatic transmissions w/o a modulator (overdrives like TH700R4/2004R). I would run a vacuum line to the modualtor after it's been checked for being bad/leaking vacuum. The detent (kickdown) cable can be left disconnected if you want to shift manually. If the whole cable's missing you'll definitely want to plug the hole in the case where it enters to keep dirt and water out.
Anyway, here's info on ID'ing your transmission. |
| small block chevy vortec heads & intake | liquid launcher | Engine | 5 | 03-06-2011 06:05 AM |
| 283 small block/Vortec heads combo | mannyandlily | Engine | 6 | 11-14-2009 12:57 PM |
| having problems rebuilding my 350 small block | camarofanatic86 | Hotrodding Basics | 4 | 04-09-2009 12:52 PM |
| vortec heads 400 small block | greaser666 | Engine | 12 | 04-25-2005 06:19 PM |
| Vortec Conversion For Small Block Chevy | M-1-4 | Engine | 3 | 11-20-2002 05:51 PM |
