Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350 small block wont start after warming up
Old 02-07-2010, 10:11 AM
bondo's Avatar
bondo bondo is offline
which brings me to issue #2 timing, i know for a fact that my timing gears are properly lined up and my valve train was adjusted properly but i cannon seem to get this engine to run right for the life of me it sounds like it has very subtle misses through the exhaust when at idle and when in gear it has no bottom end really at all, but once moving takes off like a bat out of hell but starts popping and not running smooth under load,
Ayuh,... You're confusing Valve timing with Igntion timing...
While they're both derived from the cam gear, they're also pretty much Unrelated...
