Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350 small block wont start after warming up
Old 02-07-2010, 04:39 PM
UPandComing UPandComing is offline
B.A.M.F
Originally Posted by Blazin72
Good cam, doesn't totally kill your bottom end and sounds good too. What is your idle speed? Are you using a progressive linkage on those carbs? What did you set your base and total ignition timing to? Do you even know?
idle speed 800 rpms, yes on the linkage, base timing if were talking the same thing i have the dot on the cam gear lined up with the dot on the crank gear, and the total ignition timing if once again we are talking about the same this is 35 degrees advanced at idle speed
