Thread Tools Search this Thread share on Facebook
  #1
Old 03-24-2009, 06:33 PM
54deadsled 54deadsled is offline
350 starter
hey guys i need a little help.i have a 350 built and i have put 3 new starters and 3 new fly wheels.it keeps eating up the starters.flywheels are ok but i have been changing them anyway just to see.i have been buying quality parts as well.tried shimming but no good.any ideas or help would be helpful.thanks chris
Register now (free) or login to remove ads
Old 03-24-2009, 06:40 PM
SSedan64's Avatar
SSedan64 SSedan64 is offline
Are you using the correct knurled shank bolts? Factory starter brace?
Old 03-24-2009, 06:43 PM
350 starter
yeah. it was in a el camino and we pulled it out and put it in my chevelle and it started this.using the same parts as i had
Old 03-24-2009, 06:54 PM
SSedan64's Avatar
Also make sure the mounting surface is clean and that the mounting holes in the block aren't cracked, can allow starter to flex. Ground wires from block to engine, firewall, frame.
Old 03-24-2009, 07:01 PM
350 starter
ok ill check that out. would it be any help to grind some off the top of the starter to make it closer to the flywheel.
Old 03-24-2009, 07:19 PM
SSedan64's Avatar
I wouldn't do that. Normally you can shim the outer part to move the starter closer. Half shim. Should be able to fit a paper clip about .060" thick between the gears for correct clearance.
Old 03-24-2009, 07:38 PM
fast68's Avatar
fast68 fast68 is offline
likes chevy trucks & boobies
theres a rod spacer tool that comes with new starters to make sure you have the right distance, its about 1/8"
a drill bit works the same
large diameter flywheel for staggered bolt starter noses and small diameter for straight across bolt noses
shouldnt be having any of this trouble if you are using the right nose for the right diameter wheel/plate
no shims
Old 03-25-2009, 11:37 AM
SSedan64's Avatar
One other thing to check. Make sure the torque converter bolts aren't too long and bottoming out in the TC. Will cause the flexplate to bow out of shape. Ask me how I know.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "350 starter"
ThreadThread StarterForumRepliesLast Post
small blcok chevy! The ultimate starter problem! S.O.S.sugar rayEngine1207-19-2007 08:07 PM
broken bolt housing on 350 block for the starterbearmacias27Engine807-13-2007 08:55 PM
Starter Problems in 350 SBCMagikalEngine1311-26-2005 10:19 AM
Starter questionszipfactorEngine608-07-2005 07:10 AM
Carry on from other Starter POSTdollybudElectrical009-26-2003 05:48 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
