Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350 starter, alternator, and flywheel fit a 283
Old 02-04-2009, 07:26 PM
i have a 283 punched 40 over, does the 350 starter, alternator, and flywheel bolt on to my engine. How big of a stall converter should i go with..
283 Bored 40 over
Summit 7129-T6 Aluminum Roller Rockers 1.5 ratio
Hydraulic lifters with a Summit Cam 254/264 .533/.555
Summit Bracket Racer SFI Harmonic Balancer
Eagle I-Beam Rods with the small journal (5.7 in length)
Original crank, forged
Weiand high rise intake
Speed pro forged pistons
Double roller timing chain
375 double hump heads. reworked with the big valves
Rotating assembly balanced and blue printed
650 edle. carb
headman headers
True duals with no cats.
411 posi unit
b and m shifter
350 turbo tranny
hei distr.
summit ignition system with rev limiter
taylor wires
all input is greatly appreciated
