Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350 starter, alternator, and flywheel fit a 283
Old 02-04-2009, 07:33 PM
poncho62's Avatar
poncho62 poncho62 is offline
Wiki Edits: 5
Yes......it will all fit as long as the block is drilled for the 350 starter.....It should be. Another thing...What water pump are you using...short or long? Your heads may not have the boss to mount the alternator with the long pump.
