Thread Tools Search this Thread share on Facebook
  #1
Old 02-04-2009, 06:26 PM
BIGWISEXY BIGWISEXY is offline
350 starter, alternator, and flywheel fit a 283
i have a 283 punched 40 over, does the 350 starter, alternator, and flywheel bolt on to my engine. How big of a stall converter should i go with..
283 Bored 40 over
Summit 7129-T6 Aluminum Roller Rockers 1.5 ratio
Hydraulic lifters with a Summit Cam 254/264 .533/.555
Summit Bracket Racer SFI Harmonic Balancer
Eagle I-Beam Rods with the small journal (5.7 in length)
Original crank, forged
Weiand high rise intake
Speed pro forged pistons
Double roller timing chain
375 double hump heads. reworked with the big valves
Rotating assembly balanced and blue printed
650 edle. carb
headman headers
True duals with no cats.
411 posi unit
b and m shifter
350 turbo tranny
hei distr.
summit ignition system with rev limiter
taylor wires
all input is greatly appreciated
Register now (free) or login to remove ads
Old 02-04-2009, 06:33 PM
poncho62's Avatar
poncho62 poncho62 is offline
Last journal entry: 51 Ford F1
Wiki Edits: 5
Yes......it will all fit as long as the block is drilled for the 350 starter.....It should be. Another thing...What water pump are you using...short or long? Your heads may not have the boss to mount the alternator with the long pump.
In the words of Walter Cronkite..."And that's the way it is."
Ontario Rodders
Old 02-04-2009, 08:00 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
Socially Unsociable
It also depends on what flywheel/flexplate you plan to use. The 153 tooth 12 inch flywheel uses the straight bolt pattern starter. The 14 inch 168 flywheel uses the staggard mount starter. You`ll need to check your block to see if it has provisions for both starters.
I don`t know what purpose you plan to use this engine for so I will say if you plan for any street duty you are way over cammed. A cam that size will need at least a 4000 stall, again way too much for the street. To run a cam that size in a small cubic inch short stroke 283 you must be planning on revving it way up there.
Old 02-04-2009, 08:08 PM
Lee Phillips Lee Phillips is offline
AMEN to that!
Also, you will need a LOT of compression to make that cam work - pistons A. H. A. P (Dome as high as possible), small chambers, etc.
I had a '66 El Camino my stepson wanted to put a long cam in; a 283. It was a DISMAL failure, ate spark plugs, never could get it jetted right. It also ate several turbo 350 transmissions.
I would be real surprised if you weren't a lot happier with a smaller cam (assuming this is not in some kind of race car)
Old 02-04-2009, 08:38 PM
jimfulco jimfulco is offline
If you find your 283 has the holes for the starter, make sure they're threaded. My 283 was a '59-model, and the inboard hole was not threaded.
Back to top
Search this Thread:
Advanced Search
vB code is On
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
