350 starter mount bolt hole broken... - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-24-2010, 07:58 AM
I have a 1970 k5 4x4auto with a 85' 350 5.7 in it. I recently started having starter problems and was shocked to notice that the mounting bolt hole (the one that is farthest away from the engine ) has a chunk of metal broken off of it. this is a 3/8 inch in length piece that makes a pizza shape from the top to bottom and is at least 3/8" accross the bottom where the bolt would normally start its threading. I have two questions.
1. are the odds that i started having starter issues due to tThis piece that broke off? I guess what I am saying is these starters can get touching by adjusting.........just one shim...so if the piece broke, and the secure mounting integrity was loosened....would this have caused my starter problems..??
2. How in the world do you fix a broken off piece that secures somthing as heavily used as a starter is...... as well as heavy as a starter is.?
I have never heard of such an issue before and have worked on chevy small blocks on various vehicles off and on for 20 plus years.
Old 03-24-2010, 08:06 AM
Last journal entry: B-body disc rotors
search
check previous threads - there was one about this very problem within the last week or so.
Old 03-25-2010, 11:55 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
Welcome to HotRodders.com Glad to have you with us.
Try here, & if you use this item, be sure to use the starter to engine brace.
if there's no brace on yours, that probably helped cause it to break.
Rich
http://www.classicchevy.com/product....8&dept_id=1315
SBC Starter Bolt Pattern, Patterns? 63ChevyII Engine 13 09-21-2012 08:43 PM
Broken starter Bolt!!!! The worst Ive ever seen!! JDogg92 Engine 7 06-06-2010 11:07 PM
Question on SBC mini starter bolt pattern eric32 Engine 2 11-10-2009 07:43 PM
Staggered or straight mount starter? HotRodMan Engine 5 09-12-2006 09:30 PM
Transfer case - NP 203 - 205 jrm123180 Transmission - Rearend 2 03-24-2006 07:36 AM
