350 starter trouble - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-21-2010, 01:59 PM
350 starter trouble
im having trouble with the starter not engaging and just sticking on even after the key is turned to the off position any help would be awesome
Old 11-21-2010, 03:02 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
The starter has a solenoid that does (2) things.
It engages the starter pinion gear to the flywheel ring gear.
And it makes the electrical connection to run the starter motor.
It seems like the linkage is broken between the solenoid and gear and has jammed the solenoid in the on position which is continuing to keep the starter motor running.
vicrod
Old 11-21-2010, 05:24 PM
EOD Guy's Avatar
Sometimes called a bendix, it pushes the starter gear, held back by a heathly spring, forward to engege the teeth on the flywheel. Some things to check: the bolts that hold the bendix to the starter might be loose (unprobable), the spring has become weak (unprobable), there is a loose wire from the starter to the bendix, the bendix has burnt up or the starter has become misaligned and won't allow the starter gear to retract.
Old 11-21-2010, 07:48 PM
Cape Cod Bob's Avatar
Do a search on here , this has been covered a gazillion times and I am sure you will get a faster anawer that way,
Old 11-25-2010, 02:51 AM
i had the same issue once.. it was a bad ignition switch. turned the key off, and the contacts stayed in the 'crank' position.
the starter motor was smoking by the time we got the battery cables off.. that prompted our new shop policy.. first thing that happens to any customer's car that comes through our doors.. gets a quick-disconnect on the battery.
350 starter mount bolt hole broken... oldschool70k5 Engine 2 03-25-2010 12:55 PM
350 starter hell dikki706 Engine 32 05-15-2009 09:26 PM
Starter shifting and grinding.. new starter? Where does starter brace go? 84Z Engine 8 11-12-2007 03:44 PM
Wiring 350 and installing dist. (im in trouble) 66IMP Engine 12 09-07-2007 02:12 AM
350 starter won't line up right-? 31 Ford A Engine 21 08-26-2006 08:51 PM
