350 stock camshaft - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-30-2004, 06:28 PM
350 stock camshaft
Hi, I have a quick question for you SBC guru's. I've searched through all of the old posts and haven't found the answer to my question.
How can I tell if my 350 is made for a hydraulic roller cam? (without dismantling the engine if possible?)
Any help would be greatly appreciated, and let me know if more info is needed.
Thank you,
Tyler
Old 11-30-2004, 06:44 PM
NXS's Avatar
NXS NXS is offline
wind & fire = guides to power
You are pretty much going to have to pull the VCs or intake...but if you tell me the year maybe...
Old 11-30-2004, 06:46 PM
I dont quite understand what your asking. If you want to know if you have a roller cam in it with out removing the intake, You can remove a valve cover and run the engine. If its a roller cam the push rod wont spin. If it just a regular cam they will spin. Check several of them because you could have some that wont spin due to a lifter worn so that it cant spin. At least thats my story.
Gary
Old 11-30-2004, 06:51 PM
strikingthematch's Avatar
Pure American Muscle
Last journal entry: Still Going
As far as I know if you look down the dis. hole you will see a spyder which holds the lifters in place. Thats not on all blocks but on some I don't know the exact years. Other then that the lifters on later blocks have a flat side on part of the lifter that holds them in place so they can't turn in their bores you might be able to see this on the back lifters in the block. What would be really easy would be to take the mani. off and check.
Chris
Old 11-30-2004, 06:52 PM
Gary
Thanks for the replies guys,
I will find out what year the block is, I dont have the info handy.
I just want to know if I can put a hydraulic roller cam into this motor.
I DO know that motor has '68 307 heads, intake and 2bbl carb. Does that help?
Thanks,
Tyler
Old 11-30-2004, 06:58 PM
NXS's Avatar
NXS NXS is offline
9 outta 10 says no factory roller cam but you can retro fit a Comp or other brand.
Old 11-30-2004, 07:13 PM
What would be involved in the retrofit process?
Old 11-30-2004, 07:22 PM
NXS's Avatar
NXS NXS is offline
Old 11-30-2004, 07:30 PM
Originally posted by NXS
So in other words, it aint worth it! Thank you very much.
I can pretty much assume that it'll have hydraulic flat tappets then....?
Old 11-30-2004, 07:44 PM
Siggy_Freud's Avatar
Worth it if you have the dough. Your looking at a new cam, a set of roller lifters, and then all the gear to make them work in your setup.
Looking at 200+ for the cam, 200+ for the lifters, and probably 150-200 for the retrofit kit.
But if they (car manufacturers) went to a roller cam design and havent since gone back you know something is good about them
Bringing history and technology together.
Old 11-30-2004, 10:15 PM
I see the logic, thats forsure. Makes sense, I'm just unsure if the expense is necessary for the application.
Truth is, its not my car, I'm just sourcing info for a brother in law, and he's on a tight budget. He isn't building the 350 for crazy horsepower, he just wants some inproved street performance.
This is getting a bit off topic, but I think he's looking at intake, carb, headers and a cam. Internals other than a cam will be all stock. With these upgrades, in your guys' opinion, is a roller cam/roller lifters worthwhile?
We really appreciate the help and input, thanks a bunch,
Tyler
Old 12-01-2004, 04:20 AM
Without the money to reto fit a block i'd have to say no. A roller cam is great it really is and like others have said there is a reason why new engines have them in.
Heck any dyno test will show you what they do. I too am building an engine and have looked at the roller cams. I just can't bring myself to spend that kinda money on them though.
Put it this way I can buy a kit from comp cams for $240 with cam/lifters/timing set and a roller cam will cost over that much just for the cam!
I could then buy over 7 cams at say $80 before before im at the same price as a roller set. Not to metion if you go with a roller you have to buy the full set with cam/resto fit lifters/ spyder/timing set with cam button/ shorter push rods/ springs/ the works.
So in my thinking no without a lot of extra cash just sitting there it's not worth it for a street engine.
Hope that helps
Chris
Old 12-01-2004, 03:19 PM
Nail in the coffin. Flat tappet it is! Thank you very much for all of the replies.
Tyler
Old 12-01-2004, 03:39 PM
New Member
350 stock cam
Tyler
what are you trying to do with the motor.
Old 12-01-2004, 04:51 PM
Re: 350 stock cam
Right now it is a stock 350 in a '68 Chevelle mated with a th350 transmission I believe.
Looking to add a bit more punch to it strictly for the street. Plans include headers, intake, carb, and a cam. Sticking tightly to a small budget.
