350/t350 chirps tires and dies when put in gear
hi i have a 1963 chevy pickup that i have just put a new trans in it is a t350 with a locar shifter when i first got it it ran fine for two days and then the problem started i checked the timing with and without a light and checked the vacuum lines nothing was bad so i tried replacing the torque converter and it still has the same problem any ideas? everything is stock
There may be a stuck valve in the valve body that controls the line pressure in the transmission. The transmission is operating at full line pressure instead of regulating the line pressure. (Low at idle and low throttle input, part throttle driving,, high at high rpm and WOT)
This is part of what controls the shift firmness. Often its a small piece of dirt or grit that jams the valves in the valve body. Not so uncommon on a new build. A trans tech can fix it in about 20-40 minutes. Removing the trans is usually not nessessary. Drop pan and valve body. Dissassemble and clean valve body, reassemble. Once its fixed it likely won;t happen again. Just one of those things. |
| SBC won't idle right and dies when put in gear | multicar | Engine | 4 | 12-22-2010 09:52 PM |
| 89 camaro dies when put in gear | brownk2010 | Transmission - Rearend | 15 | 01-10-2010 11:28 AM |
| t350 gear changing problems | benns | Transmission - Rearend | 1 | 11-03-2009 05:43 AM |
| engine dies when put in gear | starchief | Engine | 4 | 07-22-2003 07:35 PM |
| Chevy Astro chirps tires when taken out of Park | Forkliftguy | Engine | 2 | 06-17-2003 12:25 AM |
