Thread Tools Search this Thread share on Facebook
  #1
Old 07-25-2004, 03:19 PM
IWANTMOREHP's Avatar
IWANTMOREHP IWANTMOREHP is offline
New Member
350 TBI to 350 TBI VORTEC SWAP
What would I have to change over if I wanted to change my 93' Chevy Silverado 350 5.7L TBI to a 95 5.7L Vortec?
Register now (free) or login to remove ads
Old 07-25-2004, 07:25 PM
edge's Avatar
edge edge is offline
Time is short, are you ready?
You will need a Vortec TBI intake and a driver's side exhaust manifold for Vortec engines along with the EGR tube. You will probably need to install a different chip as well.
Pace Performance and Scoggin-Dickey could both sell you what you need for the swap. Also, check out CFM Technologies for they specialize in TBI performance.
If you have the cash, you should also consider Edelbrock's Multi-Point Fuel Injection Conversion Kit . I just put one on my 94' Suburban with the stock 5.7 engine, but the Vortec conversion is advertised to produce 265 HP and 340 ft/lbs. It comes with everything except the in-tank fuel pump and exhaust manifold or EGR tube kit. You can buy their pump or a pump for a 91' Firebird GTA at a local parts store. It is an easy swap and works and performs as advertised, at least for the stock engine.
Good Luck! Ed. www.edgesz28.com
Old 02-04-2009, 08:42 PM
1989 k1500 vortec 1989 k1500 vortec is offline
i have done this to my pickup and the intake is all you need
Old 02-05-2009, 02:32 AM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
Socially Unsociable
Are you certain you have a Vortec engine? The name Vortec has been used since the 80`s. In 96 GM started using Blocks on the truck line with roller cams, windage trays and the better Vortec heads. Since you say your engine is a 95 then it could be the same engine you have now which is a flat tappet cam, no windage tray and the horrible swirl vane heads. The better Vortec heads have 8 intake bolts in a straight up pattern. The swirl vane heads use the classic 12 bolt pattern. I may have just said all this for nothing but I just wanted to make sure you knew what you had before you jumped in as I`ve seen many be confused by the name Vortec just as well as I`ve seen guys trying to sell "Vortec" heads that are swirl vane heads just because of the name.
Old 02-05-2009, 12:24 PM
oldbogie oldbogie is offline
1995 is not a Vortec, L31 commenced with the 96 model.
You need to be a bit more definifive with what the 95 is, a Vortec would not have TBI it has a thing called Central Sequential Fuel Injection. Aside from the words Fuel Injection, it shares nothing in common with TBI.
That said, TBI can be adapted to a Vortec headed engine by using a GMPP or Edlebrock intake that bolts to Vortecs at one and and TBI at the other.
The other simple swap is to use the Swirl Port heads off earlier engines and the TBI bolted to a Vortec bottom end.
Some confusion comes in 95 5.7 liter engines as late production started using the 880 Vortec 4 inch bore block. But these used Swirl Port heads and TBI, the only thing Vortec about these engines is the roller cam block. One also needs to be wary of 305s which were called Vortecs for quite some time before 1996, but never had L31 style Vortec heads on them, just the name is all.
To put a true L31 into a TBI vehicle and use the CSFI of the Vortec will change the fuel system starting with the in-tank pump, fuel lines, computer, and wire harness. A lot is involved with this swap.
Bogie
Old 02-05-2009, 05:40 PM
va4cqd va4cqd is offline
the vortec name has been around since the mid 80s
also, this thread has been dead for over 4 years
Old 02-05-2009, 07:19 PM
machine shop tom machine shop tom is offline
ZOMBIE THREAD !!!!!!
RUN AWAYYYYYYYYY!!!!!!!!!
tom
Old 05-02-2012, 06:40 AM
Socially Unsociable
This thread started out in 2004, then again in 2009, and now again in 2012. You brought back a old thread to tell us that?
Back to top
Search this Thread:
Advanced Search
vB code is On
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
