Check the fuel pressure. Check the vacuum lines. These engines are notorious for carbon plugging up the vacuum ports in the throttle body causing it to not get the correct vacuum signal to the map sensor. May also want to check the spark timing.
I had some time today to work on it a little, I wasn't able to hook up a gauge to test vaccum but I did pull off most of the lines and non of them seemed to be clogged.
I also bought a kit and rebuilt the fuel pressure regulator. Made no difference. I pulled off the vaccum line that goes to the power brake booster (Removed from manifold) just for the hell of it and it suprisingly made it run significantly better, not perfect though. Does this usually hint at anything? So far the FPR, MAP sens, and egr have all been pulled off and cleaned or replaced. The timing was right on the money. I will check fuel pressure tomorrow but I'm pretty confident its something computer related. Alldata's spec for fuel pressure was 9-13 psi |
Unplug the coolant temp sensor on the front of the intake, next to the tstat houseing.
Fuel filter was the first thing I replaced.. I'll check it out again to see if it clogged up. I added 5 gallons of gas right after I started having problems just to make sure that it's not picking junk off the bottom of the tank.
At this point I have replaced the map sensor, checked voltage range on the TPS and IAC, and rebuilt the fuel pressure regulator using both the new spring and the original spring. Also checked the voltage going to all the sensor and all of them were recieving power (around 5 volts) and all grounds were fine. I am going to replace the map sensor again just to make sure I didn't get a bad one, along with the fuel filter. If that doesn't solve anything then I'm out of ideas. |
coolant temp sensor.
The first thing I thought of was the fuel pump but, you haven't had any hard starting problems. The next thing is the throttle body injectors. I would look down the throttle body while it's running with a strong led flashlight. There should be a cone shaped fuel spray coming out of them both. If not, they need replaced. It's not uncommon for injectors to go bad after 20 years.
350 TBI fuel issue
The fuel, no matter how the truck is running, always comes out in a cone shape. I'm starting to wonder if I have a short to ground somewhere within the map circuit. As far as fuel pump goes, at first I thought it was too but even if it was slowly dying the motor should still be able to idle, which it's not. I could be wrong but that was just my guess on it. |
| Distributor Tuning and Theory - Part 1 | Rick WI | Engine | 35 | 04-26-2011 12:38 AM |
| !!!!! HELP - CARBURETOR LEAKING & FUEL TANK NEEDS TO BE CLEANED!!!!!!!!!!!!!!!!!!!!! | islandman | Engine | 3 | 03-17-2007 03:36 PM |
| 1981 converted to 350 tbi info needed | ghomer | Engine | 1 | 01-29-2007 10:15 PM |
| no spark or fuel 350 tbi? | downhilleric | Engine | 5 | 12-09-2004 08:45 PM |
| TBI 350 no fuel or spark? | downhilleric | Introduce Yourself | 1 | 12-07-2004 09:16 PM |
