Thread Tools Search this Thread share on Facebook
  #1
Old 01-13-2009, 07:35 AM
Eric64 Eric64 is offline
350 tbi ignition coil connections
Hope you can help, I've gathered all these parts for a TBI conversion now I'm double checking to make sure I've got all the parts. I've checked all the wiring diagrams I can find and it's probably real simple but I can't find it. On the ignition coil there are 2 modular plugs and the high tension lead connection. I've got the cable that goes to the distributor and is connected to 1 of the 2 plugs on the coil what or where does the other plug on the coil go to? Thanks, Eric 1993 chevy p-up TBI
Register now (free) or login to remove ads
Old 01-17-2009, 08:38 AM
ellis ellis is offline
the black plug and gray plug slide together own the coil and the small wire own the gray plug wire is a hot wire i plug my hot wire to tac to it
Old 01-17-2009, 10:10 AM
66GMC's Avatar
66GMC 66GMC is offline
Get in, sit down, hang on
Last journal entry: Air Compressor / Cooling Tower
NAPA Echlin #IC29 coil
NAPA Echlin #EC25 Black connector
NAPA Echlin #EC26 Gray connector
I just looked at the wiring diagrams on Autozone, and they only show 2 wires going to the coil. White is for tachometer.
I've got a 92 GMC pickup, so let me pop the hood and see what I can see.
Maybe I'll even post a picture, depending on what I find.
Old 01-17-2009, 04:51 PM
66GMC's Avatar
OK... (viewing the coil with the coil wire terminal facing rearward)
The black connector attaches to the passenger side of the coil, and goes directly to the distributor.
The Gray connector (with the heavier pink wire) goes on the driver's side, and the wires go up the harness to the ignition switch. The pink wire is hot, and the white wire is used to trigger the tachometer.
HTH,
Don
PS.
I did take pictures, but I don't think you'll need them.
Old 01-19-2009, 07:46 AM
Thank you so much for the info. I figured it would be easier to find a diagram but ..Thanks also for the pictures and the part numbers. Eric
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "350 tbi ignition coil connections"
ThreadThread StarterForumRepliesLast Post
350 TBI spark problem driving med crazy!!ErstEngine1204-26-2007 10:18 AM
1981 converted to 350 tbi info neededghomerEngine101-29-2007 10:15 PM
Help me pick- Electronic Ignition CoilFrancisElectrical2704-24-2006 05:11 AM
Ignition Coil resistance QuestionOld School NutEngine306-11-2005 03:36 PM
350 GM Goodwrench Caprice engine in 3rd Gen TBI F-Body?wrmason3Engine209-14-2002 07:01 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
