350 TBI stalling issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-09-2011, 07:21 PM
got an 89 chev C1500 350 TBI, at an idle at operating temp it shudders until it shuts off, i have officially done everything i can think of i just need another path to take any ideas??
Old 07-09-2011, 07:24 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Changed thread title, should get more responses.
Semper Fi
Old 07-09-2011, 07:58 PM
Clogged cat convertor?
Old 07-10-2011, 02:33 PM
455olds's Avatar
Does it restart right away. I had one that would not restart for hours and it was a bad pickup coil. Coolant Temp Sensor failing? Try Chevy Talk also.
Old 07-10-2011, 02:39 PM
I was thinking control module, but it really sounds fuel related to me with it sputtering before it stalls.
Old 07-11-2011, 08:25 AM
so not temp sensor or pick up coil or control module it starts right away but i already replace all those along with the whole distributer so i got the pickup stator as well and the egr but most of the problem was cause by a clogged check valve on the brake booster which i replaced as well along with fuel pump both injectors fuel filter batt and alt and timing chain and iac tried plugs untill the platinum delcos. finnally the truck does it only at opperating temperature and not as often but there is still something wrong i was gunna try the IAT next wish me luck
oh and i gues sputtering would be a bad description of what it does its more of a looping idle i wish i had a tac so i could be more spacific but its like itll rev up a bit and then idle so low it shakes also i forgot to mention that the oil pressue gauge will spike and fall with the idle and then maintain normal while the truck idles normal
Old 07-11-2011, 10:55 AM
GMCBEAST's Avatar
Had a similar prob with my '88 Jimmy and it ended up being O2 sensor. Drove me crazy, of course it was one of the last things I thought of. Hope this helps.
Old 07-11-2011, 12:03 PM
Race The Truck
Last journal entry: Son's Truck
I will tell you with out a scaner and a shop manual to read what the computer is tell you its a shot in the dark most common problem are the ground wires iac egr fuel pump water temps which the computer read to adjust the timing and fuel! Now all then little do dads have a range that they run in and if there bad or out of adjustment. you will never know with out a scaner! and like me when I got my 89 your just throwing part at the problem! Welcome to the computer age!!
Also you might want to go Here! www.fullsizechevy.com They eat walk and talk trucks!
Craig
Old 07-11-2011, 02:14 PM
I was wondering about the IAC and possibly vacuum leaks myself.
Stalling out or something? FiLkY tha FELON Engine 3 05-22-2006 07:57 PM
new sbc stalling bigolblackie Engine 3 04-22-2006 07:54 PM
350 TBI stalling crshrmn3 Engine 13 03-17-2004 02:13 AM
350 tbi stalling out punk1c5040 Engine 0 02-12-2004 08:48 AM
350 tbi stalling out punk1c5040 Engine 1 02-12-2004 08:47 AM
