350 TBI Starting Problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2009, 08:55 PM
I have an 88' k2500 with a 5.7l tbi 350. It was sitting for the last couple of years, so I replaced the basics (fluids, oil and fuel filters, battery..... ect...). A couple of months ago I got it to start (had bad gas, probably not a great idea) and it continued to run for about twenty minutes; but it quickly died and wouldn't start. By watching the injectors I figured out that they wouldn't fire. So I poured some fresh fuel into the throttle body and it would fire up for a few seconds and run like a beast. That still left the problem of the injectors; the first thing that came to mind was the fuel pump, from the outside of the truck there wasn't an audible sound so I thought it was dead. Turned out later (after draining the old fuel and pulling the tank off and checking the pump) that it wasn’t it because nothing changed. I ended up catching my engine on fire because of petrol residue on the block and split ignition coil wire gapping. This ended up burning up one vacuum hose (so my engine will run lean). I replaced the old coil wire with a new one and I'm not worrying about the vacuum tube just yet. Later on after giving up for about a month I decided to try it again but after turning the key into the ignition I found out that my radio and heater were dead. I pulled the fuse cover off and was browsing the different places and one caught my eye; it said 10A INJ A+B, wow I felt really stupid. I put new fuses in and now the injectors will fire and I have spark but even with starting fluid it won't fire at all. What is the problem?
Old 01-30-2009, 12:12 PM
heavy chevy!!!
i had the same problem
check your electronic ignition module in the distributor
Old 01-30-2009, 02:46 PM
I have already pulled it off and cleaned it. Now I know I have spark because I've pulled every spark wire off the plug and they are tapping.
Old 01-30-2009, 06:26 PM
heavy chevy!!!
have you rechecked the sparkplugs to make sure there not fouled? if they are clean and sparking strong make sure the injectors are squirting while the engine is turning. My trucks fuel pump would cut in and out. If it stops working kick the tank that works sometime
modded 350 tbi power est. 90GMCVortec Engine 4 10-26-2008 09:32 AM
350 TBI suggestions needed crshrmn3 Engine 5 12-06-2003 10:28 AM
Very "lazy" '88 350 TBI help newsuburbanite Engine 9 12-01-2003 05:57 PM
Switching from olds 350 to chevy 383... and now I've got problems matching up trannys elukas Transmission - Rearend 6 08-26-2003 12:03 PM
85 chevy 305 heads on an 89 TBI chevy 350? jazzguitar Engine 4 11-03-2002 04:11 AM
