350 tbi timing off.. anyone can help? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-05-2008, 08:32 PM
i have a 94 silverado w/ a 350 tbi it was running good in idle but when to drive off it felt like it was going to die and after certain speed ran w no problem. then my friend told me that the time was off he tried to adjust it with the timing light but it seems like it got worse, after adjusting it and shut it off the truck wont start or you hear the starter hitting the flywheel if you turn the distributor then it stars but idles bad if you move the distributor the way it idles good you can hear like explosions trough the exhaust and we cant get it right. does anyone know what would be the problem and how it could be fixed?
Old 10-05-2008, 08:43 PM
espo1980's Avatar
If it doesn't fit force it!
new engine build?
Need to know if you pulled the engine or replaced parts? Something else to go on. If Its a new engine, you need to recheck all the plug wires and fire order. Distributor could be in a tooth off.
Old 10-05-2008, 09:00 PM
kc0kfg's Avatar
kc0kfg
When your friend adjusted the "timing" was the timing wire distributor unplugged?
It's a single wire leading to the distributor on the pass side of the harness closest to the distributor, if that was not unpluged when you turned the static timing of the distributor the computer will try and fight what you are doing.
The wire needs to be unplugged then the distributor timing can be adjusted, then turn the truck off, plug the wire back in and the ecm will now use this point as its starting point.
When you went to adjust it was it lose? if it was tight I would look else where for the issue.
Brian kc0kfg
Old 10-05-2008, 09:01 PM
the motor never came off all we did was to change spark plugs, distributor cap, distributor rotor, oil change basically a tune up. we also replaced the fuel pump and fuel filter.
Old 10-05-2008, 09:04 PM
Brian kc0kfg
i dont think that the wire was unplugged. also when we were using that timming light it lloked like it was mis-firing or at least thats the way the light was shwing
350 TBI to 350 TBI VORTEC SWAP IWANTMOREHP Engine 8 10-20-2016 09:57 AM
Power and Fuel Econ Porblems with NEW STOCK 1994 350 TBI MuscleBlock81 Engine 12 09-08-2009 11:01 PM
1989 Chevy 350 TBI Timing Primevci Engine 9 01-31-2009 05:13 PM
Timing a GMC 2.5 with TBI ronrw2b2 Engine 3 08-27-2004 09:25 PM
Timing on 350 jeff germano Engine 5 10-04-2002 06:56 AM
