350 timing
Hello,
I reinstalled a freshly rebuilt 350 (bored 30 over, new rings, pistons, cam, timing chains, valves, etc.) into my 1980 Corvette (L82, automatic) and started it today. I ran it for about 40 minutes running between 2000 and 3000 rpms. I let it cool, then ran it again for about 45 minutes, even drove it briefly around the block. Here's the problem: the timing is supposed to be 12 btdc. When I set it there, the idle runs extremely high (1600+). So I turn down the idle, and the timing is off! What am I doing wrong? I disconnected and plugged the vacuum from the distributor (which drops the rpms), then set the timing, idle etc. When I set the idle to 1000 rpms, it drops to 500 in drive and stalls. How do I get it to idle properly AND be at the proper timing AND not stall in gear? Should I try it with the vacuum attached? Any help would be greatly appreciated. JG700 |
Do you have a vacuum leak somewhere?
No idea. I had a reputable machine shop do it. I do know that he used a "better" cam (more lift?). Would that change the timing?
Cam won't change ignition timing. Vacuum leaks will make the engine idle high and cause you to chase your tail...
I also noticed that the idle speed varies from 900-1300 within seconds, shorts bursts up, then drops down. Vacuum?
| 350 Chev timing, compression, vac...HELP | 33PlyCoupe | Engine | 9 | 07-20-2009 10:41 PM |
| Timing for my 350? | fastrehotrods | Engine | 16 | 12-11-2006 09:49 AM |
| SBC 350 Timing | 75gmck25 | Engine | 7 | 11-27-2006 04:44 PM |
| timing problem? 350 chevy | 95th67cam | Engine | 5 | 02-19-2006 04:16 PM |
| Timing on 350 | jeff germano | Engine | 5 | 10-04-2002 06:56 AM |
