38-40 degrees timing is a spec given to be used in what they deem a high performance drag engine. Using old fulie heads, not smogger heads, w/domed pistons and "good" gas, in a race vehicle- the title gives you a hint at what the book was aiming to do. The heads/pistons/fuel used is a far cry from smogger-type specs. Take a close look at the cover. Does that engine look to have smog heads? Regardless, you are in error if you think that OEM heads make best power at 40 BTDC in anything approaching normal conditions and circumstances. |
Bottom line here is: "If your motor needs 40° total timing, there are quite a few ponies left on the table in the overall combo" ,
The same information is published in the 1994 version of the book. besides a book written right at the point of smogger engines should have good real time tuning experience. The book wasn't referring to the picture on the front cover. the 38 to 42 spec was intended for "street engines". The "race setup" was 38 to 40 as recommended by "chevy engineers". Well, looks like we will disagree on this one. "Slow burn heads" just need more timing for max power, it is that simple. And BBC's need even more timing. Sure, the old smogger engines will still run with 36 degrees but will be a little short on max power. |
You’ve (unsuccessfully) taken my comment out of context, but to no avail.
The thread is about an iron (993) headed SBC in a Jeep. At post 168 you chime in w/a very helpful “a 383 I read about in a car rag made max power at 40 degrees” or words to that effect. (An odd-ball build that was obviously made for a supercharger or was just lame to begin with- who builds an engine w/8.1:1 CR and puts a cam in it w/almost 240 degrees @ 0.050”?)Then about 10 posts later, you (very helpfully ) back up and pull out a book that hasn’t seen a revision (reprinting the same thing is a reprint- not a revision) since it was printed in 1976, that references 40 or 38 to 42 or whatever degrees of timing. For max power in a drag engine. W/pop-ups and a points-type ignition. If you have something worthwhile to contribute, then I’m sure everyone would like to hear it. But being a troll helps no one- especially yourself. |
but ported, mild hydraulic cam, stock valves) made its best MPH at the track (113) w/34 degrees. I later changed to 215's and found I needed a bit more timing, settling finally on 35 degrees. It was built for a Blazer, but I broke it in, in my Camaro for S&G's.Too bad the OP doesn't have a BBC in his little blue Jeep- this thread probably wouldn't exist! But the thread (w/one not notable exception) HAS been informative, w/good give and take, a few good laughs and just plain good ol' FUN! I've not thought as much about vacuum readings or timing in quite a while, and it is refreshing. Last edited by cobalt327; 02-14-2010 at 03:45 PM. Reason: Don't feed the trolls. |
Back on topic.
I see that Blue has 369 casting heads, so I was in error when I said 993's above- I thought I saw that on this thread, and had jotted them down as such, but oh well. I have no experience w/369's. Mor Tec has them as: 33417369...90-up...350..........Gen.I Goodwrench crate motor,"Hecho en Mexico", 76cc I'm guessing they're not the swirl port-type heads, but more like standard, run o' the mill-port heads. That said, does anyone have any particulars on these heads? |
getting old iron heads to flow? (SBC) |
To get the spread reduced between the initial and the full mechanical advance you will have to limit the amount of travel of the mechanical advance plate. This can be accomplished either with small bushings in the slots or by shortening the length of the slots by welding them up. Doing this will enable you to get the initial up to a more desirable 18 degrees while limiting the total mechanical to 36-38 degrees. Once again, the "all in" @whatever RPM is controlled by the return springs and/or the weight of the advance weights. It is very common to get an acceptable reading by swapping out the return springs. The springs can be mis-matched as well. i.e. I have found that one light spring and one medium spring will work well in a GM HEI to keep the "all in" RPM close to the often desired 2600 RPM figure. Going to the 3000 RPM figure is Ok, but is a little high in my opinion for max power under typical street driving condition. A lot will depend on your typical cruise RPM's as to what the "all in" RPM should work best. Quote:
If you are still limited to 2 degrees, I think you will find that there is something binding or restricting the advance mechanism. |
Good advice, all.
FWIW, w/the dist. cap off, you should be able to draw by mouth (or use a MityVac-type hand operated vacuum pump) on the disconnected end of the hose to the vacuum can, to watch the vacuum advance work. By doing this you will easily be able to discern any lack of movement and by "assisting" the movement by hand as vacuum is being applied, you will see if there's a impediment to the action of the plate. |
Frisco,
he has a accell 71100 and it doesn't say if 28c is possible setting,,,(new it was 24c),,,"see enclosed instructions for centrifugal changes" http://www.accel-ignition.com/pdf/71000.pdf blue, yes you want the cent to start around 12-1300 because that's when the convertor starts to grab and put a load on the motor lol, clear as mud instructions???? 71100 has some form of a "vacuum advance lock out feature" for race only for plate control (and plug the body hole?),,, I don't know what it is,,,how it works,,,,but it could ber why the vac adv units are not working.... Last edited by red65mustang; 02-15-2010 at 08:47 AM. |
| Timing question on 350 sbc | eric32 | Engine | 6 | 08-03-2009 07:10 PM |
| What the ***** is wrong with my timing cover/ harmonic balancer!!! | sexypizzaman | Engine | 56 | 10-28-2008 03:49 AM |
| Timing for my 350? | fastrehotrods | Engine | 16 | 12-11-2006 09:49 AM |
| timing problem? 350 chevy | 95th67cam | Engine | 5 | 02-19-2006 04:16 PM |
| Timing on 350 | jeff germano | Engine | 5 | 10-04-2002 06:56 AM |
