What RPM is the mechanical all in by? AFA the TCC lock up goes, you can easily run a vacuum switch that will disengage it when the vacuum drops below a preset value. I keep going back to the photos of the Jeep . Are you gonna put some miles on the highway w/it? Or more for show or off road?
re:I just read post #30!!!
wish you had posted that at the beginning,,,fair chance your vac gauge is not calibrated correct or it's leaking.... (garbage in=garbage out for reference points) 3.73 and OD is less motor load/higher Hg at 70 than eom typical 3.08 and OD.... Hg on the oem is typically 18Hg+ at 70,,,no load on the motor in the garage shows approx 20Hg at the 70mph +OD motor 2k? rpms=a healthy happy motor and drive train.... poor acceleration "power" at 70 can be timing and carb tuning,,,air resistance can be about 2-3Hg (motor load) difference at 65 or 70 but so far all your readings are consistantly off typical=bad gauge? go borrow a gauge to compare readings idle, downshift, and 70mph... (and WOT should show 2-5Hg due to 600cfm/350) quick check compare for the downshift results is in park spin the motor up to 2500+ and really quickly release the gas pedal will show the 25Hg as the no load rpms comes down... edit: I just watched the video,,,gauge does show 25Hg decelerating so the sealing test is valid... re: your "40" mech total: with your rear gears and weight anything above 36 total is not worth the (detonation) risk!!! blink your eyes really quick just once,,,that is roughly 1/10th of a second and is darn close to the actual 0-60mph ET total time difference between 34-36 and 40 total timing!!! if it is a 8.5CR motor when tuned correct you should be able to burn 87 octane no problem with 34 total!!! Last edited by red65mustang; 01-19-2010 at 07:40 AM. |
Here is another one built by a friend. Engine is a 383 Stroker. Here is a photo of the real McCoy! Although technically it is a full scale replica. I have rebuilt several airplanes. This was my 1937 Fairchild 24G. To make a long story short, after being around airplanes all my life, airplanes are for rich guys, I'll stick to the Jeep! Now I just have to learn the technical stuff! Last edited by Blue84JeepCJ7; 01-19-2010 at 03:36 PM. |
Red65Mustang - Yes the engine in the Jeep was really solid, I didn't know about single plane intakes affecting vacuum, and also didn't know about the vacuum test by down-shifting
But '84 CJ7 have you worked the bugs out of your Jeep yet ? Beautiful Jeep you got there, and nice to see another Jeep guy here ![]() Best regards |
!*How does that work AFA inspections, etc. to use an automotive engine in a plane? I've heard of VW's, Corvairs, even a 215 Buick- but NEVER a 383 stroker! Bad-A looking planes, BTW. Way outta my league, too, unfortunately. |
I just checked the total timing buy marking the balancer 10% of the 25 1/4 circumference. When I did this, the "new" 36deg mark I made is dead on the "0" on the timing indicator tab!
Now what? lol |
That particular airplane did not have a gear reduction so max power that could be used was at 3,000rpm. That engine produced 253hp@2,700rpm. Anything turning faster put the prop blade tips past supersonic and could destroy the prop! You could use a gear reduction and turn the engine up to max (6k-9k?) However, I do not to fly it like that.....yeeeooouuchhh! |
Also put the vac adv on the manifold port and nothing changed. |
Now sometimes, if the timing is VERY advanced, you can have a situation where more timing won't increase the engine idle speed. You should try checking it w/the timing light, if you aren't already. If you are and still no advance, we're back to a faulty or disconnected vac. adv. Wasn't this a new dist. or am I mistaken? |
When I picked it up from him the first time, the engine would almost quit when it changed into second gear. Then when I tried to restart it when I got back to his shop, it kicked back. I left it with him and he said he would recheck the regulator-to-pickup gap. He said he drove it before I picked it up but there is no way he could have done that with it running, or lack there-of, the way it was! I wish I knew where I could get it on a computer test bed but I am idealess! lol |
| Timing question on 350 sbc | eric32 | Engine | 6 | 08-03-2009 07:10 PM |
| What the ***** is wrong with my timing cover/ harmonic balancer!!! | sexypizzaman | Engine | 56 | 10-28-2008 03:49 AM |
| Timing for my 350? | fastrehotrods | Engine | 16 | 12-11-2006 09:49 AM |
| timing problem? 350 chevy | 95th67cam | Engine | 5 | 02-19-2006 04:16 PM |
| Timing on 350 | jeff germano | Engine | 5 | 10-04-2002 06:56 AM |
