I bought a malibu that came with a 350 with stock big chamber iron heads and victor junior intake. Story goes it was in a s-10 drag truck then bought and put and put in the malibu and not finished. I got the car and attempting to get it running. The cam is a custom grind 256 in/272 ex @.050 .390in/ .410ex lift 106 lobe step. I had the valve cover off and watched the valves to find tdc on #1 to set the distributor and when I attempt to start it it will pop through the carb and exhaust like the the distributor is 180 off but when you turn it 180 it's way worse. I called lunati and they said that grind needs 11.5-1 compression and I suspect this motor is bone stock with dished pistons. So my question is if this motor is only 8-1 compression would this be a possible cause and would bad gas have a factor? It's solid lift and I loosened up the lash, double checked the plug wires and even double checked the timing gear marks. I'm hoping I overlooked something dumb but I'm open for ideas. Thanks
Sounds like you're getting gas. Make sure it is decent as Vinnie said.
Take a hard look at the distributor cap and rotor - no corrosion. Check the wires and correct firing order.
Verify your timing mark is close (within 4 degrees), hookup the timing light and get a remote starter or a helper to crank it over and move the dizzy to 5-10 degrees BTDC.
Make sure the balancer you're using has just a single mark on it.
After triple checking everything today I finally found my issue. I discovered that I managed to put the plug wire on going the wrong direction around the distributor. I switched the firing order to going around clockwise and it runs like a beast now. Thanks to those who gave input. Your never to experienced to make mistakes will be a new motto of mine.
Been there and done that with making stupid mistakes due to ....? Glad to here it is running properly.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
