Thread Tools Search this Thread share on Facebook
  #1
Old 02-15-2009, 07:45 PM
jgh64pkup's Avatar
jgh64pkup jgh64pkup is offline
Last journal entry: new et streets
350 timing issue
i have a 350 .060 over 284 crane energizer cam stock crank and balancer aftermarket timing cover and pointer for 8 inch balancer
the problem is when i put a timing light on it the mark is nowhere close to the timing tab its at least 3 inches away
could the balancer be keyed wrong or maybe the crank
Register now (free) or login to remove ads
Old 02-15-2009, 07:49 PM
Torque454 Torque454 is offline
The outter part of the balancer could have slipped, or the distributor could be set in there a few teeth off.
Old 02-15-2009, 07:52 PM
jgh64pkup's Avatar
could it be the wires maybe i put them on in the wrong spot
i put #1 2 spots down from the right of the coil plugin
Old 02-15-2009, 08:03 PM
SSedan64's Avatar
SSedan64 SSedan64 is offline
Could be, also your after market timing cover or balancer may not be right.
There are different mark locations.>>
http://www.chevytech.com/2c44o2.html
http://www.chevytech.com/2c44.html
http://www.chevytech.com/2c46o1.html
Old 02-15-2009, 08:05 PM
roknroy roknroy is offline
how does it run? does it rev good? chevy moved the timing marks at least once...you might have mismatched components...
Old 02-15-2009, 08:06 PM
Could be. I think #1 is right next to the wires that run into the inside of the cap for the coil, 12v in, tach terminal, etc. Its a little square block on one side of the cap. #1 is the one on the front side of that square if i remember right.
Old 02-15-2009, 08:08 PM
nevermind, ssedan has all the info you need..
Old 02-15-2009, 08:15 PM
jgh64pkup's Avatar
it runs and revs greathttp://www.youtube.com/watch?v=6a4UJbtYJGQ and starts real good its probably the aftermarket timing cover
Old 02-15-2009, 08:29 PM
sounds good! youtube! your motor has to be close in timing, but i would still pursue getting it at 34 total timing, run it at a track a few times, and move it to 36,38,32, to see where it likes it. next would be jetting, if you feel like dialing it in...
Old 02-15-2009, 08:46 PM
SDLuck SDLuck is offline
timing
Chevy has at least 3 different timing pointers and balancers.
Old 02-15-2009, 08:50 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Senior Curmudgeon
Location: In da woods, Union County, North Carolina, USA
Wiki Edits: 326
Yep, Noon, 2:00 O'Clock and 2:30 O'Clock.
Old 02-15-2009, 08:58 PM
2:30 oclock........love it.... tater salad, and his son tater tot
Old 02-16-2009, 10:14 AM
Carlos9 Carlos9 is offline
What kind of heads you runnin with that cam if you don't mind sharing. It sounds good.
Old 02-16-2009, 10:31 AM
jgh64pkup's Avatar
1967 283 powerpack heads 60cc chamber 10.65:1 compression double springs
right now it has stock rockers on it i have some harland sharps but im missing one and i also need the polylocks
if anyone has any polylocks they want to sell just pm me
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "350 timing issue"
ThreadThread StarterForumRepliesLast Post
350 Chev timing, compression, vac...HELP33PlyCoupeEngine907-20-2009 10:41 PM
Timing IssuenovatechEngine708-02-2006 06:39 PM
timing problem? 350 chevy95th67camEngine502-19-2006 04:16 PM
Help 350 rocket bad timing chain & low oil pressure?71oldsmannEngine203-14-2005 11:45 PM
Timing on 350jeff germanoEngine510-04-2002 06:56 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
