Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350 timing marks when replacing chain and gear
Old 08-06-2013, 10:10 AM
rp23g7 rp23g7 is offline
Originally Posted by oldbogie View Post
Both positions are correct but you've got to keep track of where the in the firing order these positions are at to properly align the distributor.
With both the crank and cam gear in the 12 o'clock position the number 1 cylinder is ready to fire the power stroke and number 6 is ending its exhaust stroke.
With the crank gear at the 12 o'clock position and the cam gear at 6 o'clock the pip marks face each other making them easy to line up, however, number 6 is now ready to fire the power stroke and number 1 is ending its exhaust stroke.
To make my life simpler I always bring the number one cylinder and the distributor to number 1 firing before removing the distributor. For installation of the timing set I always pull the crank around to the pip mark facing the 12 o'clock position with the cam gear and chain installed with the pip mark in the 6 o'clock position, this makes it easy to see that you've got alignmnet between the gears. Once everything the gear alignment is verified and all the bolts are run in to hold the gear, I rotate the engine 360 degrees which brings the assembly back ready to fire number one with crank and cam gear in the 12 o'clock position so the distributor can be reinstalled exactly where it came from.
A little hint here, the distributor gear does a 1 tooth rotation toward the retarded position as the distributor is removed. This usually takes the oil pump drive with it. When you put the distributor back in if it just drops in place it's probably a tooth off so when you remove the distributor take a long screw driver or an oil pump assembly pressurization tool (essentially a distributor without a gear) and give the oil pump drive shaft a litte advancing twist (clockwise rotation). That way when you align the distributor to your removal datum point and the rotor to the number one firing position on the distributor housing it ends up right where it fires number 1 on TDC.
The datum marks are to align the housing with a easily identifiable object that aligns it's orientaion to the rest of the engine. While in that position you also mark the housing with where the rotor is when it's ready to fire number 1. Normal installtions usually have some fudge space so if your off a tooth you can rotate the distributor to regain the number 1 alignment with rotor and cap. But with space constrained installtions like a V8 planted into an S10/15 or Vega/Monza there often isn't any space to align the distributor other than how it was so it's important to mark off repeatable locations for alignment of the distributor on these type things.
great info, thanks
