350 timing problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-23-2012, 08:17 PM
350 timing problems
I am having getting the timing right on my 350zz crate engine, I thought I did everything right, but it always pings under load. I have tried a few different ways to timing, it seems like every time I time it with the timing light, a few weeks later it moves off its mark. Not sure what could be the problem. Can anyone offer some suggestions. In neutral or park I can rev the engine and there is no pinging but as soon as I put a load on it, its as though there are marbles in the engine. Thanks appreciate ur help
Old 04-23-2012, 09:41 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
It just sounds like your timing is way out of whack. What is it set at static, at idle, distributor vacuum disconnected and plugged? Should be around 12 to 14 deg for starters, and no more than 34 or 36 total.
Semper Fi
Timing problems darren rogers Engine 11 10-11-2010 09:23 PM
timing problems 350 Wildwestshow Engine 8 09-28-2010 07:04 PM
chevy 350 timing problems Wildwestshow Engine 5 09-24-2010 04:54 PM
sbc(350) timing mark problems jw4413nv Engine 6 08-29-2006 02:29 PM
Timing Problems 80 Chevy C10 Engine 15 09-12-2002 08:33 PM
