350 tranny - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-08-2006, 05:41 PM
350 tranny
hi, i have a 350 tranny that hasn't been run in i4 years. its sitting behing a 327. i know what to do to get the engine started but nothing about the tranny. can someone out there help? also, it does not have a yoke. [no driveshaft]. will the missing yoke cause it to leak upon startup? thanks
Old 08-08-2006, 06:04 PM
I would go ahead and install a new front pump seal, a filter and pan gasket, a rear seal and a shifter seal ... to make sure you have no leaks ... and YES ... no yoke will cause a BIG problem ...
Old 08-08-2006, 08:27 PM
tranny
thanks deuce for the info. appreciate it...smokey
305 head on 350 savman1 Engine 4 10-15-2006 09:18 PM
350 turbo tranny not shifting to 3rd actionphilson Transmission - Rearend 1 11-17-2005 06:22 PM
Ever have this happen to your tranny? Help BudLight Transmission - Rearend 6 06-12-2004 09:21 AM
chev 350 tranny bettylew Transmission - Rearend 1 11-10-2002 05:48 AM
Will a 5-speed pontiac tranny hold up to a 350?? chevyelc81 Engine 4 05-24-2002 07:20 PM
