350 tranny free wheeling - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-05-2013, 09:43 PM
Now that I've got some free time, i'm going to rebuild the 350 tranny that I took out and replaced. It worked good but it started free wheeling in second when I backed off on it. I'm sure that is the roller clutch that has gone out, but wondering if its something else. I was told that there is a better part replacement if I rebuild it. Has anyone had any experience with this problem. Would like to have some input about this before I open it up.
Old 10-05-2013, 09:54 PM
Proud LOSER
Mine did the same in my vette, been 2 full summers, many low 13 second passes and a gazillion burnouts and general stupidity, current owner pounds it often and it still has the same issue..... no idea why or what's broken, just know it hasn't effected anything ....weird.
Old 10-06-2013, 07:43 AM
Mine did that two years ago and it didn't affect anything also, but since i'm going to rebuild it, I though i'd fix it, what ever it is. Told that was a common problem with the 350. Also told that it is a roller clutch and there is an upgrade for that problem. don't know what that upgrade is and though someone might know.
Old 10-06-2013, 11:09 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
When does this free wheeling happen? What shifter position? "D" or "2" .... what road speed?
If the shifter is in "2" , there should be engine braking with the coast band applied
Old 10-06-2013, 11:13 AM
vinniekq2's Avatar
the coast band has the end spot welded,common failure
Old 10-06-2013, 12:57 PM
It only happens when in second. When I back out of it, it just goes into free wheel or neutral type feel. It just coast when your off the throttle. I'm thinking it is a roller clutch. Mentioned it to a older fella who worked at Chevrolet dealership years ago, and he though it was a roller clutch. Said that there was, if he remembered it correctly an upgraded part to replace it with that was better for the higher performance vehicles. Said it wasn't a problem for the everyday driven vehicle, but it was for performance vehicles. Noticed it the first time when I tried to use second gear for braking down a steep hill. Was the original tranny in my nova two years ago. Has about 60 thousand miles on it.
Old 10-06-2013, 04:49 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
When in manual 2nd gear and you lift off the throttle. Engine drops to idle.
It is the roller clutch working. The rollers clutch over runs and the engine drops to idle. As I said , the coasting band is not working. band holds to provide engine braking
Could be a broken band strut as mentioned
Free Motor and Tranny davidcasanueva Hotrodders' Lounge 5 01-12-2004 09:25 PM
Free turbo 350!!! BillyBob1950 Transmission - Rearend 3 02-20-2003 12:05 PM
