-   -   350 Trans Cooler Fitting Size (http://www.hotrodders.com/forum/350-trans-cooler-fitting-size-186562.html)
david-b 10-25-2010 09:18 AM
Hey all. I'm replacing the trans cooler lines to SS, and trying to find the right size fittings. Seen online a couple places say 1/2 in.-20 Inverted Flare and then seen others say 1/4". Does anyone know what they are for sure? Thanks much.
SSedan64 10-25-2010 09:31 AM
Fittings that go into Trans case are 1/4" NPST/NationalPipeStraightThread not Tapered Pipe Thread.
http://www.tciauto.com/Products/Tech...r_fittings.asp
Most of the Line fittings are 5/16" Inverted Flare.
david-b 10-25-2010 09:41 AM
Perfect thank you. Seen that site and that was the first one saying the 1/4" NPST
Got it all ordered finally! Comin together
