350 Trans Cooler Fitting Size - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2010, 09:18 AM
david-b's Avatar
Dave is THAT guy
Hey all. I'm replacing the trans cooler lines to SS, and trying to find the right size fittings. Seen online a couple places say 1/2 in.-20 Inverted Flare and then seen others say 1/4". Does anyone know what they are for sure? Thanks much.
Old 10-25-2010, 09:31 AM
SSedan64's Avatar
Fittings that go into Trans case are 1/4" NPST/NationalPipeStraightThread not Tapered Pipe Thread.
http://www.tciauto.com/Products/Tech...r_fittings.asp
Most of the Line fittings are 5/16" Inverted Flare.
Old 10-25-2010, 09:41 AM
david-b's Avatar
Dave is THAT guy
Perfect thank you. Seen that site and that was the first one saying the 1/4" NPST
Got it all ordered finally! Comin together
Trans Cooler frickenbored Transmission - Rearend 1 04-12-2010 02:33 PM
So, what does the trans cooler look like inside the radiator? Photos MARTINSR Hotrodding Basics 16 10-10-2009 08:28 AM
Th350 cooler lines.... sexypizzaman Transmission - Rearend 8 06-17-2008 11:50 PM
350 turbo trans problems,,, tiresmoke55 Transmission - Rearend 10 04-06-2007 08:08 AM
air conditioner rad for trans cooler? cboy Transmission - Rearend 15 01-17-2005 02:53 PM
