350 trans cooler lines - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-16-2011, 09:10 PM
Hey guy's, Im building a 30 model A coupe with a 350 chevy 350 trans, and I need to make some trans cooler lines. The tranny has some fittings in the holes now and Im using a walker radiator with the cooler in the bottom tank. the radiator fittings 1/8 pipe and the tranny looks like 3/8 pipe does that sound right. will these lines be enough to cool this stock tranny or should I try to put a remote cooler in? I don't really have room for a remote so i would like to use the cooler I have. Bill
Old 08-16-2011, 11:37 PM
SSedan64's Avatar
The Trans case fittings are 1/4" NPST/NationalPipeStraightThread to 5/16" Inverted Flare, Rad is probably 1/4" NPT/NationalPipeThread to 5/16" Inv.Flr.
Water cools 32 times better than air so it should be fine unless you plan to use a TC/TorqueConverter with a high stall rating, then I'd recommend an Auxillary cooler aswell.
Are you going to use Metal lines or Braided Hose?
Many places sell Hose kits & fittings.
Example> http://www.summitracing.com/parts/SUM-220027/?rtype=10
Trans oil cooler lines ? Carlos Murphy Transmission - Rearend 1 11-13-2009 01:06 AM
trans cooler lines eatonde Engine 7 10-17-2008 06:42 PM
Trans cooler lines JJ350 Transmission - Rearend 9 03-08-2007 02:25 PM
Trans. cooler lines Novaman78 Transmission - Rearend 12 10-08-2006 07:15 AM
Trans cooler lines which is which atlantis Transmission - Rearend 44 01-08-2006 04:19 PM
