There is a lip type seal inside the aluminum housing held in place with a cir-clip ring and the o-ring is around the OD of the aluminum housing it runs in.
hi, you say there is a lip type seal inside the tail housing and the o-ring sets against the fixed lip seal? Is there any photos available of this setup and also are you saying there is no seal at the plastic speedometer shaft inside the aluminum bullet looking cable housing? Thanks
Here's a pic for you the one on the left has the seal installed and the other one don't have the seal installed.
Cole |
db ....
IF you have an aluminum speed-O bullet the shape and size of the unit on left in foto by Cole.... throw it away and purchase a steel unit as the left in foto. Aluminum bullet is worn out by the plastic gear. If gear is worn , replace it too
At the Bonneville Salt Flats, first gear is known as 130 mph. |
thanks for the photo and info guys. The photo on left seems to have an almost seal looking image around the plastic gear shaft, where as the one on right does not. Is the one on the left the steel one I should get? Thanks.
thought I was clear with : Quote:
Never know... my typing skills are poor and sometime I leave words out. The folks here usually catch that for me
| 86 trans am gas leak | tweed | Engine | 2 | 04-16-2010 12:03 PM |
| trans leak | blue85350 | Transmission - Rearend | 15 | 01-02-2007 08:47 PM |
| trans leak | Lonestar | Transmission - Rearend | 11 | 07-20-2006 09:51 PM |
| Trans leak | jamn50 | Transmission - Rearend | 1 | 03-23-2005 06:44 PM |
| 79 Trans Am T-top leak | RideDannyRide | Interior | 3 | 09-29-2003 04:45 PM |
