350 trans leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-26-2013, 05:04 PM
350 trans leak
If my front seal is leaking would I see fluid on my converter and flywheel? Reason I asked is because I dropped my trans pan because there was fluid around my front pan gasket and seen someone also had some rtv along front maybey previouse leak. After trk sits it leaks about a quart. If I try a gasket should what is the best rtv along with the gasket, red? Thanks Dana
Old 05-26-2013, 05:39 PM
Banned
fix the pan first as it's the easyest..
it might be leaking out the dipstick tube. as the truck/car sits the fuild drains back from the converter. basicly over filling the trans and it will leak out a dipstick tube thats not sealing or missing the o ring..
and yes if it was leaking out the front seal it be on the coverter If leaking while running I'd while your changing the pan gasket.. spray brake clean on the front face of the trans converter area.. and get it nice and clean.. then if you see a line of red fuild running down the front behind the converter after sitting you'll know thats it..
mine leaks there when sitting, and I'll change it when I r&r the engine.
good luck.. my bets on the o ring and dipstick tube
Old 05-26-2013, 07:45 PM
350 turbo trans ?
I did change complete rubber seal that tube fits in that seems to be o.k? Thanks for ideas
T-350 trans leak 39chevy Transmission - Rearend 10 05-07-2013 09:14 PM
350 trans. leak db flyer Transmission - Rearend 8 01-08-2011 09:34 AM
trans leak blue85350 Transmission - Rearend 15 01-02-2007 08:47 PM
trans leak Lonestar Transmission - Rearend 11 07-20-2006 09:51 PM
Trans leak jamn50 Transmission - Rearend 1 03-23-2005 06:44 PM
