What kind of shifter are you running is a aftermarket floor type ? And where exactly are you seeing the leak at ? it could be the shifter shaft seal/dipstick tube. sometime you really have to chase these thing down. JMO
Also what type pan do you have on it ?
Cole , The shifter is column shift by Lokar no leak there. The cooler line is a bit damp, the pan is a new cast aluminum with rubber gasket. Found most of leak is actually from rear main blowing back and mixing with what little is coming from pan gasket. Thanks
I have a stock 350 motor I am going to install, and I am going to install a turbo 350 trans, does it matter if it is a short or long tail? If so what is the advantages or disadvantages? Thanks, Dana
You should start your own Thread but, Length doesn't matter strength wise.
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
