350 trans with metal in pan - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-15-2002, 04:56 AM
Question 350 trans with metal in pan
last thursday my truck made a kind of whining noise from the tourque converter(i think).so today i drain the fluid and dropped the pan.in the bottom of the pan was a thin layer of gray slime and the filter was cloged but it also had a thin layer of gray slime on it.is my trans shot out or is this normal wear and tear?
Old 12-15-2002, 06:47 AM
Post
I have seen this before and it hasn't caused a problem. As long as it's a very thin layer and doesn't look like metallic paint.
Old 12-15-2002, 06:06 PM
BOBCRMAN@aol.com's Avatar
Post
the whining noise was the pump starving from the plugged filter, the matallic stuff is from wear in the geartrain. the yellow tinted stuff ain't gold but costs like it.
Old 12-15-2002, 08:33 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
Gray stuff is normal clutch wear. should be ok w/ clean filter.
