We're winning the case!
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 07-14-2008, 08:24 AM
39chevy 39chevy is offline
350 trans que.
Im installing a Lokar shifter in my 350 trans,I will make sure it is a 350, my que is, when my shift handle is installed and when I push it all the way to the front of vehicle to put in gear what gear would that be, then next etc? Explain from front to rear, thanks, Dana.
Old 07-14-2008, 09:41 AM
XNTRCI-T's Avatar
XNTRCI-T XNTRCI-T is offline
AKA Lee in KC
Unless you have a reverse shift pattern, all the way forward will be Park, next detent back is Reverse, next is Neutral, then Drive, then Second, then all the way back is First.
Old 07-14-2008, 10:15 AM
SSedan64's Avatar
SSedan64 SSedan64 is offline
JackOfAllTradesMasterOfNo ne
Reverse shift pattern only changes the Forward Drive gears from P-R-N-3-2-1 to P-R-N-1-2-3.
Old 07-14-2008, 10:30 AM
XNTRCI-T's Avatar
AKA Lee in KC
Yep, sorry I didn't make that clear.
Old 07-14-2008, 12:27 PM
trans shift pattern
Thanks a million guys, GOD I LOVE THIS SIGHT.
Old 07-14-2008, 12:47 PM
dawg's Avatar
dawg dawg is offline
NAVY VETERAN
gee on the first post i was thinking you skipped english in school?
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "350 trans que."
350 turbo trans problems,,, tiresmoke55 Transmission - Rearend 10 04-06-2007 08:08 AM
turbo 350 trans not shifting out of 1st phillip24 Transmission - Rearend 3 02-25-2004 11:34 AM
350 4x4 trans to 700R4 2x4 trans swap??? punk1c5040 Transmission - Rearend 1 02-01-2004 11:14 AM
350 trans rebuild? jwart Transmission - Rearend 0 09-21-2003 08:06 PM
Turbo 350 Trans Vacuum Signal? 54 Chevy Transmission - Rearend 2 07-22-2002 04:33 PM
