350 Trans slipping please help :( - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-27-2003, 01:41 PM
Hi,
I had my tranny rebuilt and fitted it myself. on the first real journey out (about 50 miles round trip) we had apipe come off from the trans to the oil cooler resulting in loss of fluid. I got the pipe back on and limped the car to friends (about 2 to 3 miles) and replenished the fluid (with a circlip this time <blush>) and drove home a little low on fluid(?) I thought. since then we went to a show and things were fine. until the other day when visiting other friends, fine up until we cam to go, and then the car slips in drive with a judder if it is revved. Reverse id fine but 1st 2nd and 3rd all slip. I checked the fuid which now seemed high. so drained a quart out which took it about 1/2" below the hashing on the stick, but it still slips
the fluid I removed smells slightly and there were some small dusty particles in the bottom of the tray.
Have I ruined my trans? I am supposed to be the wedding car at a friends wedding in 2 weeks.
please help!
Thanks
Old 08-27-2003, 02:03 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
I'll put my money on your forward clutches being toast.
Old 08-27-2003, 02:16 PM
not good news, but why? is it the low fuid that did it? should I have not limped the car to friends but got them to come to me?
Old 08-27-2003, 02:29 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
What probably was the thing that killed it was when you limped to your friends. How many quarts low was the tranny when you first noticed it was low? The symptoms you describe (good reverse but no forward gears and the fluid smells with small dusty particles), suggests the forward clutches are gone.
Old 08-27-2003, 02:42 PM
we put in 4 quarts in all. is this a big (expensive) job?
Old 08-27-2003, 03:05 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Over there in England I bet the shops look at an American car kinda' how we do an English car. Going by that, I would say it's not going to be cheap by far. I do know that over here if you pulled the tranny and looked around, you should be able to find someone to patch it for less than a couple hundred bucks total parts and all. If you did it all your self, you could do it for less than fourty bucks total. I'll say about twice that in your neck of the woods. To just drive the car to the shop and say "fix it", would cost about 800-1200 dollars or more here.
Old 08-27-2003, 03:09 PM
wont be driving there! (unless in reverse all the way!!!!)
It'll be a case of drop it out and give it to em
Well 200 Miles to wreck a rebuilt trans must be some sort of record???
Old 09-11-2003, 09:08 PM
i built a 4l60 that went less than 25 miles, i rolled the small lip seal on fwd. clutch piston, even after air checking it 10 time' s. it was in a 4x4 chevy sub. it took out every clutch pack. verry costly come back good luck c-ya sling
Old 09-11-2003, 09:36 PM
senor_limpio's Avatar
The Dude
DIY?
Nice attack... You're too cool! I'll admit that I may not know everything there is to know about transmissions, but I have rebuilt a few in my day and none crapped out on me. Just because I don't own a transmission shop doesn't mean I don't know anything about transmissions. If my comments are not appreciated.. I will not post here...
Rock on...
Old 09-12-2003, 06:57 PM
adtkart@aol.com
Re: DIY?
Originally posted by senor_limpio
Is it possible for you to replace the clutch packs yourself? It does sound like they're toast. If you haven't pulled it yet, you might wanna even try just replacing the filter. May be all clogged. But like was already said... symptoms sound like toast.
Typical comment from someone that knows nothing about transmissions. As has been posted on this board numerous times. It WILL NOT do any good to change the trans filter on a trans that is not working. The only thing that changing the filter will help, is the financial condition of the business that sells the fluid and filter.
If there is anything in the pan that will plug the filter, the trans is junk. I don't for the life of me, understand where you people think this stuff that "cloggs" the filter comes from. If changing the fluid would make the trans work, it will also cause additional damage to hard parts that are not included in a rebuild kit by allowing you to use it while it is destroying itself..
Old 09-12-2003, 07:16 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Cool I enjoy the comments
Old 09-12-2003, 08:57 PM
airworld2's Avatar
put a fork in it , its done. forward is gone rebuild time..... enough said!!!!!
airworld2
