350 Trans will not shift - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-01-2011, 05:31 AM
Sometimes I have a problem when really mashing the gas peddle from a dead stop the automatic trans (350 trans) does not like to shift up into second. You have to let off the throttle a hair to get it to shift. However when just cruisin down the highway and you mash it it will drop down a gear,tach up,and then shift just fine. What would be the problem here?
Old 05-01-2011, 07:20 AM
willowbilly3's Avatar
Last journal entry: Body mods
I would check the vacuum lines to the modulator and if they are all good, replace it first. Also pop that round cover off the side and pull the governor out and see how the plastic gear on it looks. If it isn't either one of those things you need some one smarter than me.
C4 Trans Shift Kit? 70gmcer Transmission - Rearend 5 08-30-2009 08:34 AM
trans shift steve t Transmission - Rearend 1 09-17-2005 01:42 PM
Trans seems to shift into neutral during the 3-4 (overdrive) shift Rocketmann66 Transmission - Rearend 2 06-12-2005 11:21 AM
trans shift kit chev kev Transmission - Rearend 4 02-08-2005 08:32 PM
Trans Shift kit sscamaro_510 Transmission - Rearend 12 01-11-2005 04:39 AM
