Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350 Transmission
Old 08-20-2012, 12:17 PM
123pugsy's Avatar
123pugsy 123pugsy is offline
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
TH350 has a suare pan with one corner cut off at 45 dgrees. The TH250 looks the same except it has a threaded stud with a nut on it, I believe just behind the bellhousing on the pass side. The 250 is junk and won't stand up to much.
The 350 should be OK for a mild 400 CID motor.
