350 transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-05-2009, 06:26 PM
350 transmission
got a 74' 350 transmission with a hair line crack on the side of the tranmission where the cooler line go in,is there any way to fix crack like J B weld or what
Old 06-05-2009, 06:33 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
yea it can be fixed. People weld the trans all the time. With out seeing it though just how bad is it ? Oh buy the way welcome to the site Cole
Old 06-05-2009, 09:10 PM
small
it is about 3/4 long and like the size of a hair
Old 06-05-2009, 09:22 PM
SSedan64's Avatar
Remove the cooler fitting and grind a shallow V-notch along the crack. Not in the threads tho'. Clean it with Brake parts cleaner and smear the JB in the crack and threads, put a little Antisieze on the fitting an screw it in, let it set up a day or two. Or have it welded. And don't over tighten the fitting like someone has already done. 26-30 ft/lbs torque.
Old 06-05-2009, 09:29 PM
eloc431962's Avatar
Wiki Edits: 37
If you do as noted in the post from ssedan64 JB weld should be fine. Just make sure to clean it properly before you put the JB on. Cole
Old 06-05-2009, 09:37 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I have never seen this repair work. Best of luck with the attempt
Old 06-05-2009, 09:47 PM
eloc431962's Avatar
Wiki Edits: 37
Let us know if the JB weld works if thats the route you take. Cole
Need help for transmission yoke for turbo 350 eric32 Transmission - Rearend 8 04-28-2009 08:58 PM
Chevy 350 to a Buick transmission steveskylark Transmission - Rearend 6 07-16-2005 11:44 PM
transmission problem turbo 350 jester429 Transmission - Rearend 1 10-04-2003 07:34 PM
Turbo 350 Transmission Leaking 63 vette Transmission - Rearend 2 02-19-2003 05:02 PM
1965 c10 - 350 w/3.73 rear and manual transmission... nyabinghi Transmission - Rearend 0 01-28-2003 12:37 PM
