350 transmission conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2009, 12:44 PM
Hello all ~ I've removed a 250 straight six engine w/trans from my '66 Chevy C-10 and am now having to reconfigure the new 350 transmission mount. Can anyone tell me what year of truck I can snag one of these from that will fit onto my '66 chassis w/out too much hassle or re-engineering?
Thanks for all the help!
Old 05-11-2009, 01:09 PM
Wiki Edits: 31
LMC sells those parts new
Old 05-11-2009, 01:50 PM
Thanks Matt! I looked at the online catalog and only saw transmission mount kits. I was also hoping to save some money vs. buying new. I'm just curious to see if there's another year of vehicle I can take this from. If new is the only option then I'm forced to go there....
Thanks again,
Chief
Old 05-11-2009, 10:27 PM
sikxsevn's Avatar
HP Junkie
if you can wait, I'm about to be getting a '70 chevy truck(v8, either TH350 or Th400, not too sure). Only thing I need it for is the tranny, if there's something else there that will help you along, speak up.
Old 05-12-2009, 01:10 AM
fast68's Avatar
likes chevy trucks & boobies
72 and older is exact same chassis
auto crossmember and everything identical
same crossmember for all three auto trannies used in these years
i have an auto one sitting in the attic right now here if you want a pic
also FYI '72 and older used 6" tail th350 trannies, unlike 73-up
welcome to the forums
Old 05-12-2009, 08:44 AM
Excellent info gents! A photo would be useful if it's not too much trouble fast68...
Thanks for the offer sikxsevn ~ Depending on where you are it may be easier for me to visit the local scrapyard in San Diego.
Thanks again all!! I'm a novice when it comes to engine/trans work. It's me, a book and this blog for now....so your input is greatly appreciated!!
'til next time....
Chief
Old 05-12-2009, 09:00 AM
SSedan64's Avatar
Lots of Info here for your old 47- Present Chevy.
http://67-72chevytrucks.com/vboard/index.php?
Transmission Information. M&M CUSTOM Transmission - Rearend 1 08-24-2004 03:15 PM
turbo 350 transmission kickdown stuck 1957GMC100 Transmission - Rearend 0 12-21-2003 04:48 PM
365 to 350 Conversion agentsmith90255 Engine 1 08-14-2003 04:30 PM
350 turbo transmission nelson350ss Transmission - Rearend 5 03-20-2003 04:22 PM
Manual transmission conversion kemo Transmission - Rearend 0 12-04-2002 01:25 PM
