350 turbo - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-06-2011, 07:49 PM
350 turbo
I have a turbo 350 with a transgo kit in my race car (1500lb) never had a problem this year 1st time out wouldn't shift to hi.I don't shift. i put it in drive let it shift itself, i run no vaccum to modulater, has always worked fine drained fluid looked good pulled gov. looked fine. I did just unhook the downshift cable and put a cover over it could that somehow have something to do with it.We did finally get it to shift but took a long time and then it banged into gear never tried it again had engine probs also. thanks
Old 06-07-2011, 04:34 AM
sqzbox's Avatar
My pipes are my music
Maybe you ought to hook up the modulator and shift detent cable the way it should be and try again.
turbo 350 to turbo 700r? diamond mike Transmission - Rearend 5 04-28-2010 10:34 PM
Thrush Turbo or Dynomax Super Turbo? henkelphoto Engine 3 08-24-2006 11:46 PM
350 turbo to 400 turbo swap in lemans?? mtmniles Transmission - Rearend 8 01-24-2006 12:40 AM
Turbo 350,Turbo 400,700R4,Or Muncie 4 Speed nightrain_rod Transmission - Rearend 2 04-18-2003 12:35 PM
400 turbo to 350 turbo problems mikeweyman Transmission - Rearend 2 04-02-2003 05:58 PM
