350 turbo - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-12-2012, 02:42 PM
350 turbo
top trans. line goes to were on radiator. Or does it matter what line goes were?
Old 02-12-2012, 05:58 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
You should be able to tell by the different length of the lines where they actually go. But IIRC the flow goes in through the bottom and out from the top on the cooler in the radiator. But it should work either way as it is cooling the fluid as it passes through it anyway. JMO
Cole
Thrush Turbo or Dynomax Super Turbo? henkelphoto Engine 3 08-24-2006 11:46 PM
non turbo to turbo eclipse Dainleljedal06 Engine 1 07-31-2006 10:13 AM
350 turbo to 400 turbo swap in lemans?? mtmniles Transmission - Rearend 8 01-24-2006 12:40 AM
Turbo 350,Turbo 400,700R4,Or Muncie 4 Speed nightrain_rod Transmission - Rearend 2 04-18-2003 12:35 PM
400 turbo to 350 turbo problems mikeweyman Transmission - Rearend 2 04-02-2003 05:58 PM
