yes transmission will bolt up, as long as its a buick ,olds or cadillac transmission. move cross member back holes should already be in that frame,if not drill out holes as need drive shaft is the same lenth if you use short tail 400 change u- joint and yoke if you have a good parts store old part number precision u joint 372 might be inter change with other u joint manufacter number need to change fill tube and dipstick,relocate vaccume line to mogulator
