350 Turbo Front Seal Destroyer - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2010, 08:12 PM
I have a rebuilt 350 turbo with new torque converter but I can't keep the front seals from blowing. They blow within 5 miles of use. Have gone through 5 seals and getting tried of changing them. The tranny was rebuilt and worked for awhile before going through the seals - even chaged the torque converter with on luck. Suggestions? Thanks
Old 02-01-2010, 09:03 PM
tnsmith10's Avatar
when will it rain???
check the pump bushing. make sure its in the right place. i have a feeling that its walked out towards the seal.
Old 02-02-2010, 07:26 PM
Thanks. Never thought of that, I'll be sure to check.
Newer 96 350 Block fitting to a old Turbo 350? Chevytruck Engine 5 10-07-2008 01:47 AM
Can I put a turbo 350 in place of 700r4? eric32 Transmission - Rearend 7 08-23-2008 02:51 AM
rear oil seal help alrobjr Engine 5 01-24-2006 08:12 AM
Turbo 350 shift shaft seal Blackdog Transmission - Rearend 4 01-04-2006 07:39 AM
350 front seal oil leak buddy Engine 4 08-29-2002 06:25 AM
